I wish thier was something easy, you could just spray into throttble body, or port at the intake manifold. But in reality, i guess thier isnt. The valves never come into contact with fuel basically. they just open and close, as the injecotrs on todays modern cars, are placed below the valves. hence, what ive learned, the only real way too clean them up and out...removal of the manifold. In my case, chilton book, says too remove the upper radiator hose, which means draining it. Its a timely process for all this. a day off thing.
Spraying seafoam, berryman, whatever even through the pcv valve might do some cleaning, if cleaned like every 10,000 miles, ide imagine. Ive never done that on this car, 98 corolla. 84,000 miles now, and it did have oil burning problems, like half a quart, to 75% a quart in 1,500-1,700 miles. it only burns less than half a quarter a waurt now by 4,000 miles. so i can only imgaine what the intake must look like.
im running seafoam in new oil right now. maintenance. do 4,200 mile oil changes, because at that mileage, which i average 6 months, the oil has turned thickish n black. menaing also the filter is full. put 7 ozs for 4 quarts.
