I'm looking to get a set of new Taurus/Explorer 18 x 8 steel wheels on my Grand Marquis. The bolt pattern (5 x 114.3 mm or 5 x 4.5") is the same, however, I'm not sure on the offset. Some sources say it's 44 mm, some say 35 mm. The offset for my application is -6 mm depending on the wheel, although a 0 mm offset can also be used without any trouble.
Assuming it is 44 mm, can I get away with a 1.5" spacer? Thanks!
