Earlier today, we had a customer who insisted that we resurface his original brake rotors instead of installing premium aftermarket replacements. Since we do not own a brake kathe, we sent the rotors to another shop to have the resurfacing work done.
Upon getting the rotors back, we washed the rotors with soap/water (to prevent metal shavings from embedding into the new pads) and re-installed them onto the vehicle. As always, we checked the rotor runout after cleaning the hub flange very well. Now keep in mind that this particular vehicle's manufacturer specifies a maximum allowed runout value 0.014"...
https://flic.kr/p/GtUqdU
In the video, you can see that the rotor has 0.009" of runout!!
When customers insist, we have their rotors resurfaced on a bench lathe. Most of the time (regardless of who does the resurfacing), the rotors come back with at least 0.005" of runout. The only way to make them usable is to use runout correction shims. Most vehicle manufacturers allow no more than 0.002" of runout.
In comparison, when using new premium rotors, we almost never have an issue with getting runout readings of 0.002" or less; usually 0.001" is no problem.
People always say that resurfacing rotors causes them to "warp faster," but the real issue is that most operators of brake lathes are unable to resurface rotors correctly. As a result, the freshly resurfaced rotors have a ton of runout (sometimes more than before they were resurfaced) and this quickly turns into disc thickness variation...which causes a pedal pulsation complaint after a few thousand miles. So, if you really want to resurface your rotors in the field, the best approach is to use an on car lathe.
