Originally Posted By: DWC28
I am fairly sure there are several causes for transmission whine. I am curious as it seems the OEMs may be trying to solve a problem which they have not yet acknowledged and may never do so. It seems to be occurring in transmissions with smaller sumps and higher pressures. One solution has been to add baffling around the rotating parts so they do not contact the ATF (have you seen that?) Another is more anti-foam which as it is not soluble in ATF creates problems on its own. Also I may just be imagining it.
In my experience, most of the "zizz" like whine comes from the torque converter area and it has been due to pump wear, pump leakage, or pump bypassing.
My friends tranny shop did have a tranny one time that had a sort of modified "zizz" like whine and it turned out to be a crack in the flex plate near one of the attachment bolts.
