Technically, there is no such thing as SAE 10 motor oil, because the SAE has not defined a 10 high temperature grade.
They have defined low temperature grades, all denoted by a "W" following the number. OW, 5W, 10W, 15W, 20W, and 25W are all grades that could be formulated and approved by the API for sale as low temperature monogrades.
We have all gotten used to seeing multigrade oils such as 10W-30, and that means that the oil meets the cold flow viscosity requirements of a 10W monograde, and the high temperature viscosity requirements of a 30 monograde.
Before multigrade oils became commonplace, people would have to change their oil to run a 10W (for example) during cold weather, then change to run a 30 during warm weather. The SAE viscosity classification system has been around for over 100 years, but it wasn't until the 1950's that oil makers started producing multigrade oils.
