I have always used ATF, in my oil can, to lubricate door hinges. I have kept the hinges on my truck well lubed with ATF throughout its entire life but they are worn out now and I am replacing the hinge pins and bushings.
Oil attracts grit and I am thinking of switching over to a dry lube like Liquid Wrench Dry Lube with Cerflon to avoid the grit. Will the dry lube keep the hinges well lubricated?
