In general, get it up on a lift or on stands but be SURE the car is level.
Leave the drain plug in, and take out the weep hole plug that is higher up.
Stick your finger in there, if you touch oil you are good.
To be 100% sure, add a bit until it dribbles out of the weep hole.
I think some may have a dip stick!
