Any thoughts on this report? I am a bit concerned with the Aluminum levels as most reports on this engine are around 5ppm... This is a daily driver without a load and used one a month pulling a 14k trailer.
Can this be residual from the OC that had higher fuel dilution? Also, is the aluminum only reduced because you reduced the OCI by half? No answers, I know, just questions.
