- Joined
- Nov 29, 2009
- Messages
- 7,189
I want to use the xg3614 fram oil filter which has a 14psi bypass valve. The oem filter is 8-11psi. Will the higher bypass opening pressure cause the engine to starve for oil? I want to use this on my commercial mower cause it's better than cheaper than the oem filter, except I have no idea what kind of oil pressure the engine creates. Probably not much.
