Havoline High Mileage is on sale at Walmart for $13.XX. Minus a $5 rebate. Also applies to regular Havoline for $11.XX. Both are for the 5 qt jug. Great deal!
Any name brand high mileage oil,Does that engine have a PCV valve ? If so,get the OEM version and change it. You'd be surprised how much oil burns as a result of a clogged PCV.
MaxLife Blend (red bottle) 5W-30. Start with that and do a few 3k OCIs to clean it up a bit. Go to 10W-40 after next winter if it's still using oil. Any cheap oil filter is fine. As usual, keep it topped off.
I picked up valvolibe max life blend 10w30. And some stp additive with a Ac delco filter since I try typically to remain factory on filter unless if there's a major difference in qauility.
I checked the radiator reservoir and the coolant looks fine and full. So I'll have a friend whose more mechanically inclined then me do the oil change and evaluate if it needs a valve cover gasket or not. Should be easy either way though. The hardest part Iv been told is getting to the oil filter on these motors.
Anyhow I'll take a hack saw to the old filter and post pics.
Considering where you live you can use Pennzoil HM 10w-40 or 5w-30 if you want. Valvoline also receives praise here but I have had better results with Pennzoil.
I'll give the valvoline a try for 3k miles. If me and the lady are still together ill reevaluate it at the next change.
All of my friends, and family tell me to avoid pensoil at all costs unless if I want a gummed up motor lol I'm sure its a good oil now a days but no one I know will use it. Not trying to start a flame war either lol.
It's not a flame war to point out ignorant statements.
