Originally Posted By: Kool1
Watch for wear on the plastic timing chain guides. If the chain wears through the guide, it will work through the timing chain cover into a coolant passage.
These engines are notorious for this problem when mileage starts to build up. I've been there and done that.
I'd stick w dino or syn-blend & change every 5k. Keep it full. MaxLife Blend would be a good choice.
from wiki: "The first fuel injected 22R-E engines appeared in August 1982.
Output of these engines is commonly rated at 105 hp (78 kW) at 4,800 rpm and 137 lb·ft (185 N·m) at 2,800 rpm.
In 1985, the engine was significantly reworked, output was up to 114 hp (84 kW) at 4,800 rpm and 140 lb·ft (190 N·m) at 3,600 rpm. Many parts from the newer 22R-E are not compatible with those from the older pre-1985 engine. Non-compatible parts include the cylinder head, block, pistons and many of the associated parts such as the timing chain and cover, and water and oil pumps (although the oil pump internals are the same). These changes also affected the 22R, therefore one can consider the 85-95 22R-E as a fuel injected version of the 85-90 22R with only minor differences, if any.
Toyota swapped the dual-row timing chain used in older engines for a single-row chain with plastic guides in 1983. This system reduced drag on the engine, but is occasionally problematic. Every 80,000 to 140,000 miles, the chain will sometimes stretch to the point that the hydraulic-operated chain tensioner cannot take up any more slack. When this happens, the timing chain impacts the solid-plastic driver's side chain guide, breaking it within a few hundred miles of driving and creating a noticeable chattering sound in the front of the engine, especially when cold. If the engine continues to be operated after the guide breaks, the chain will stretch rapidly (an unfortunate characteristic of single row chains). The loose chain will cause inaccurate ignition timing, which usually results in noticeably rough running. In continued operation, the chain can jump a tooth on the drive sprocket or break entirely, with either case resulting in engine damage from valve/piston collisions. Also, the stretched chain will slap against the side of the timing cover, due to the broken guide, wear through the cover and into the coolant passage behind the water pump. This will cause coolant to drain into the crankcase/oil pan, possibly causing damage to internal engine components such as bearings, crankshaft and valve train, as well as damage caused by overheating due to the lack of coolant (since it has drained into the engine oil). The condition can also render a misdiagnosis of a head gasket failure when, in fact, the head gasket may still be good. The best fix is to buy an aftermarket timing-chain kit (with steel-backed guides) and a new timing cover; 'patching' the hole in a worn timing cover is strongly discouraged"
