With that vintage, I would replace the intake o-rings if you are taking it off anyway.
If you do the thermostat housing, replace everything, it is a plastic housing and as soon as you start to take it apart the parts will be warped. I have had customer try to cheap out and just do the seals and they are coming back a couple days later for the housings.
