Originally Posted By: slacktide_bitog
Wagner just released a line of OEx brake pads for light trucks and SUV's that might work well. You might also like the Severe Duty pads, which should be good for towing as the name implies. Then there is also the Thermoquiet line which is an excellent OE replacement pad.
The best rotors would be Centric Premium, VGX Platinum, or Fremax.
The OEX pads have a very unusual pad shape and will leave a good portion of the rotor unswept.
Originally Posted By: bvance554
Is there anything wrong with the rotors on the vehicle? If not I would scuff the surface with some light sand paper and replace the pads. So many have 'pads and rotors' drilled into their heads, but if there is nothing wrong with them don't replace them, because any replacement will probably be of less quality than what you have and you'll be complaining about bad performance in a few thousand miles. Unless you totally wore the pads through to the backing your rotors should be fine.
By the time pad replacement is due, most rotors have excessive runout and disc thickness variation. To this day, I have yet to see a pair of rotors that could be safely reused without compromising results.
