I had a 2013 Mazda 3 skyactiv in the shop for some maintenance work and during my usual inspection, I found an oil leak from the hydraulic belt tensioner. Since the vehicle did not have prior dealer service history and was just outside of the 3/36 warranty period (49k), I received approval to do the repair.
Untitled by The Critic, on Flickr
Lots of oil covering the tensioner assembly.
Here is a better view of the tensioner after it was removed from the vehicle.
Comparison of the old tensioner with the new one. Both were made by INA, but it looks like the new one is slightly revised.
Made in Slovakia - that's a new one.
Kudos to Mazda for making the replacement process a breeze. The tensioner is held in place by one nut and one bolt, both being 12mm. The bolt stays in the tensioner after loosening it - it may not come out while the tensioner is still in the car. It is not necessary to remove the side engine mount for this job. MSRP on the tensioner is $134 and the whole job takes about 1 hr including the clean-up of the grease that slung everywhere (but the belt).
If you own a 2.0L skyactiv, I would keep an eye on this part and get it taken care of before it fails completely.
