Post your latest oil change
2005 Ford Focus 167,000 miles
Changed oil and rotated tires
out: Supertech Synthetic 5w-20, Motorcraft FL-910
in: Quaker State 5w-20, Motorcraft FL-910
6 months and 5,500 miles on the OC.
past 2 days
2012 Impala 3.6 V6
M1 5W30, Fram XG10060
2015 Equinox
M1 5W30, AcDelco PF457G
my uncles 2005 Dodge Cummins 309,597 miles when i changed it this afternoon, truck is very well taken care of it looks and drives like it only has 100k miles. All stock besides an MBRP 4" exhaust and just recently got a great deal on some factory 20" rims and tires off of a 2016 Dodge Cummins with only 800 miles on them. Mobil Delvac 15W40 and a Napa Gold 7620 every 7k miles
2001 Buick 3.8
3 qts Warren semi-synth 5w20
2 qts Warren semi-synth 10w30
STP blue filter
110k IIRC
I wanted an oil with high boron.I was going to use Shell conventional that Home Depot had on sale at 10$ for 5 qt jug,my nearest HD had it for 13$.So I went with Warren semi-synth at $2.50 a qt.The Warren is almost identical according to PQIA testing.It is a really quiet and smooth fill.
2011 Chrysler 200 Pentastar V6
28,889 miles
In: 5 qts 5w30 Kendall GT-1 semi, 1 qt 5w20 Castrol Syntec Blend
O'Reilly Microguard ML57526 filter
07 Honda Ridgeline
Castrol GTX Magnatec 5w-20
Honda OEM filter
122,480
07 Honda Odyssey
Honda OEM filter
134,395
2011 Honda CRV
Out: Castrol 0w20 black edge
In: Castrol 0w20 black edge
OLM at 15%
I don't track the number of miles my mom drives between oil changes.
2008 Honda Civic SI - 130000 km (81k miles)
Out: Pennzoil Ultra Platinum 5w30 -- 10k km OCI. OLM was at -2287 KM.
In: PYB 10W30 - no filter change - 5k km OCI
2015 Toyota 4 Runner 4.0 V6
friends wifes vehicle she went a little too long on the factory fill
11,229 miles when I changed it yesterday
I used 6.5 qts M1 EP 0W20 and a Wix 57173 filter, wont use that Wix again its China made
I'm so glad all 4 of my vehicles take whole quarts. I hate having an opened half bottle on the shelf. I guess it's good for top off if yours consumes any.
1992 MB W201 (190E) 2.3L
126,592 miles
Out: M1 Euro 0W-40 and Mahle OC110 (consumed 1/2qt in 2k miles - never consumed before on Amsoil - made me nervous)
In: Tried LiquiMoly Leichtlauf High Tech 5W-40 from NAPA and rebranded Wix 51088 (painted for Carquest) I got clearance deal on Rockauto ($1.41@)
Changed oil in my 06 R1, removed bosch oil filter and Rotella T6
put on same bosch filter and this time Rotella T 15w40.
also changed oil on the John Deere LT150, took off quakerstate filter and i can't remember what oil i used, either 10w30 delo or some 15w40 HDEO.
Put on a supertech filter with kendall 15w40.
today, Max-life 5w30, 2005 Buick Sabre,124,000 miles.Fram filter
Finally solved the oil usage thingie thats been going on for 2 years------changed out the PCV valve, 3 bucks at AZ, took 5 minutes...not rocket science when you watch stuff on youtube.
Airfilter...new.Fram.
Also did a transmission pan drop and filter, everything looks good at the moment....................pink is the word.
Mid point o/c filter change.
2001 Mazda Tribute v6
2 qts Warren 5w20 semi synth
O'Reilly filter
fill in the vehicle was Smitty's 5w30 semi synth
I waited until the oil level was at the add mark to do the filter change so I would be replacing 2 quarts.The oil was medium brown and the dipstick was easily readable.I am starting to have a good bit of respect for the warren stuff.
2011 Mazda6, 80k miles
Out: Castrol Edge Syntec 0w20, Fram ToughGuard w/ 9,100 miles
In: Havoline Syn 0w20, Fram ToughGuard
2001 Ford Mustang GT (4.6 2v)
6 quarts Pennzoil Platinum 5W-30
Motorcraft FL820S
7800-8200 miles on oil
Upcoming for the weekend
2000 Buick Park Avenue
AC Delco oil filter (PF47?)
2005 Ford Mustang GT (4.6 3v)
6 Quarts Pennzoil Platinum 5W-30
Motorcraft FL820S
Yeah... I like Pennzoil Platinum.
