Originally Posted By: Jimzz
Originally Posted By: rooflessVW
Dot 4 has a higher boiling point but it absorbs water faster, which lowers the boiling point of the fluid.
This is why where a Dot 4 is specified, regular changes/flushes are recommended. Dot 4 also has a lower viscosity for use in modern computer-controlled ABS systems.
Where do you see Dot4 absorbs water more? Dot3 and 4 are based from the same Glycol base and absorb at similar rates. Difference is usually between brands but not by much. That and brake systems are closed so there should be little moisture getting in.
I have also heard dot 4 absorbs moisture more readily than dot 3....? Not sure how true it is, if at all.
