I'll be doing an LIM gaskets on a 1997 Chevy Tahoe that was originally filled with Dex-Cool and there's sludge when I alerted the person driving it his coolant was low. I know GM had issues and it's common knowledge that it's not Dex-Cool in itself that's bad but rather the OEM cooling system design with the gaskets and radiator cap. My plan of attack is to flush the cooling system with citric acid and a detergent, change the LIM/UIM gaskets over to Fel-Pro's improved design, change the t-stat and install a Stant 10230 cap with a spring-loaded center.
For coolant, I want to keep it Dex-Cool or a Dex-Clone(Prestone or SuperTech) - it's easier to get and this truck is serviced by a quick lube, which also means they use an AMAM Dex-Clone. Or should I switch it over to conventional green or G-05, which I think both will work but I'm worried about potential contamination if the owner or someone else pours the wrong coolant in.
