Originally Posted By: bchannell
I have a HE lift and it's a life saver, or I should say back saver. My tractor has a fabricated 52" deck that weighs a ton. I had it off once, and will only do it again when absolutely necessary. When I want to clean the deck or change blades ramps won't do the job, they're under the deck, too low, etc. Just drive on the lift, raise, insert safety pin and clean away, plenty of room to work. I bought mine with 20% off coupon and got it for something like $79, best money I've spent in a while.
+1. I messed with ramps, blocks of wood, bricks, etc to get under the deck of my tractor for years with limited success. I bought a Mojack three years ago. Very easy to use and I can clean my deck or change the blades without it turning into a major job. I would rate my purchase as some of the best money that I ever spent on a tool.
