I put in it my sit down and it started easily. I drove it into the yert and put the front end on jack stands. The Inty is going to get its deck belt tensioner rods and springs tightened, along with a blade sharpening and greasing the mandrels. I wire brushed then PB Blasted the U bolts holding in the rear end . I bought a gallon of Universal Hydraulic fluid last yr, but could only top off a little bit.
