Just curious if this is a problem. I finished swapping out the timing belt on my 4Runner and flushed the coolant with Toyota Red. I discovered that I must have used a little too much water, because according to my hydrometer, the freezing point of the solution is about -30C (so roughly 45% EG/Water).
Here in Canada, we do occasionally reach as low as -45C in the winter. Would the concentration being off by 5% really cause any issues? Or do you guys think I should drain out some fluid and aim for a 60% EG/Water ratio to get the lowest freezing point?
