I'm looking for some recommendations for our two vehicles.
I have a 2012 4Runner Limited with about 46k miles on it. It has the 1GR-FE V6 motor in it. Currently I have M1 0w20 AFE (Toyota filter), and just realized I have over 8k miles and 9 months on the oil. I actually wasn't planning on running it that long, because with my wife's current job the vehicle has a lot of short trips. It came with the two years of maintenance when we bought it, so the previous oil changes have all been completed at the dealer--presumably with Toyota 0w20, and run for a year each.
The manual has the vague "if the vehicle is operated under load or at high speeds, a higher viscosity may be appropriate." In the next few months it will be taking a few long trips over the mountains, a couple of those trips while towing a trailer (one of them near the vehicle's limit probably)--we are in the process of relocating to a new state.
We just bought a new 2016 Mazda3 S Grand Touring with the 6-speed and 2.5L Skyactiv motor. Fantastic car so far, I can't recommend Mazda enough. We used to have a 2010 3 and it was outstanding as well. I am not ready to change the oil yet, but will probably be doing a couple early oil changes. The vehicle recommends 0w20 for the US, Canada & Puerto Rico... but says for everywhere else use 5w30. It has basically 3 maintenance intervals: standard is 6 months, severe service is 4 months, or you can use the OLM for up to 12mo/10k (US only). Our current driving meets their severe service definition, but I really don't want to change the oil every 4 months if I don't have to. I'm going to experiment a little with cost/oil benefit of premium fuel, as the engine has a 13:1 compression ratio.
My previous Toyota was a 2009 Tacoma with the 1GR-FE, which required 5w30. I ran it on Chevron dino oil on 6 month intervals from Costco, seemed to work just fine. Since these two vehicles require 11.4 qts of oil (per the manual) in an oil change, I have been kind of thinking of just switching back to the Chevron and buying a case when it's on sale and sticking to 6 month oil changes. We're also moving some place that is fairly hot in the summer. It sounds like the Mazda might end up dumping a lot of fuel in the oil, so I am a little hesitant to go to 1 year oil changes. I've never done a UOA on either vehicle, so I guess I probably should. They sell Mobil 1 at Costco as well, but I think it's only in 5w30.
I guess I am looking at:
-Switch to a 5w30, either dino or synthetic but probably dino
-Move to a 0w30, as it will probably also have fairly cold winters
-Stick with 0w20, but stay with M1 AFE or move to the EP version, and try to stay with 1 year OCIs (?)
We plan on driving these vehicles into the ground. I want at least 20 years out of them, if not more... barring any major catasrophe. If the wheels fall off, I'll staple them back on and keep going.
