Originally Posted By: dparm
Fuel dilution looks to be low, which is a good sign on the direct-injected motor (though that is the 2nd gen FSI). How big is the oil filter on that motor?
Outside Diameter (In): 2.559 Inch, Height (In): 6.102 Inch
Originally Posted By: ryanm8
I wouldn't run that long of an OCI. TBN is fine but the oil thickened up.
It was a mistake the customer made. We recommended that he stay under 8K prior to the oil change. Thankfully the vast majority of his mileage is highway miles. As dgunay stated, 10K seems to be a good interval with his usage.
Originally Posted By: deven
Any make up oil? If yes then at what mileage during the OCI?
No makeup oil. It was only ~3/4l low when he came in for the change.
Originally Posted By: BobFout
How do the intake ports look? Using a high NOACK, high SAPS oil (relative to the recommended Euro oil) in a GDI engine could lead to increased deposits.
Thank you for that! We haven't examined the ports at all. When he hits the 100K mark we'll be recommending servicing the supercharger oil, which would make it a good time to examine the ports.
