Originally Posted By: DoubleWasp
Pop oil filter off and change your filter adapter (which contains the filter bypass valve) for a new one.
An alternative is to plug the adaptor bypass with a 1/4" pipe plug & run a Duramax Diesel oil filter, Has a built in 15 PSID bypass. Acdelco PF2232 & Baldwin B1441 are a couple numbers.
