Originally Posted By: 2015_PSD
Running straight coolant is not a good idea unless you're buying a coolant which is a 50/50 mix. It can actually cause an overheating problem.
I saw this happen on a friend's car back in the '80s. 100% coolant made his car run 20 degrees or so hotter than a 50/50 mix and IMHO nothing is gained by using a 100% concentration (as shown below). I am also not a fan of mixing coolant types or colors
There are some cooling systems using 100% glycol but they have to be designed to take into account the lower thermal conductivity. The upside is a high boiling point.
