Originally Posted By: billt460
I bought a can of the Outers Foaming Bore Cleaner. This stuff was all the rage when this foaming slop came out 8 or 10 years ago. I didn't care for the stuff personally. It is sold as a... "Easy, non messy way to remove barrel fouling". I found it to be the total opposite. The stuff can easily leak into the action of the weapon you're trying to clean. Then it's a PITA to get all of it out.
The stuff only did a marginal job. Since then I discovered Bore Tech Eliminator, and I've never looked back. It works fantastically. Doesn't smell. Contains zero Ammonia. And it won't harm your barrel, regardless how long you leave it in. In fact the stuff has rust inhibitors in it. Now it's all I use to remove fouling. When I first got the Bore Tech, I ran a patch soaked with it down the barrels of the guns I used the foam on,
and every patch came out green. The can of foam promptly went into the trash after that.
http://www.midwayusa.com/product/2093155799/bore-tech-eliminator-bore-cleaning-solvent-liquid
Agreed, I used some of that gunslick foaming stuff in the past and it drives my crazy when used in an AR. Will always build up in the gas system turn to a goo and run back in the action. Even after blowing air through the gas tube. Got turned onto bore tech a while ago good stuff.
Originally Posted By: Itonlysmokesalit
I've never used hoppes cleaner. Does it leave a film of oil behind or does it act more like a degreaser, sounds like a cool idea.
Good point. I honestly don't know. My guess is that there will be a film until you wipe it off. I will get back on that.
The Hoppe's leaves almost no film. Again. I don't let my guns get filthy dirty. Can't speak hows it works on a filthy gun. I can assure it does a very good job on a firearm that gets cleaned every 500 rounds or so.
Roger I like the idea of a foaming parts cleaner more so than the bore stuff. I don't use cleaners much, usually just scrub a lot with the clp I'm using.
