'14 Focus ST Castrol 0w-40 7700 miles
Florida
New UOA from my modified 2014 Focus ST. Looking to go 10k on a change at this point. I sampled with a pump, so this oil is still in the engine. Does any more educated BITOG people see any reason not to go to 10k or any other issues? Running a Fram Ultra. Any reason an Ultra can't go 20k on a new engine such as this one?
Those numbers look very similar to ones my tuned MS3 posted(running M1 5W-30). I wouldn't hesitate to run that oil 10,000 miles.
Nice car, BTW!
Didn't realize Ford Required a 40w oil for this car? Or are you using it just to be on the safe side? Were you having Oil Consumption Issues?
Just curious...
Jeff
Just curious...
Jeff
Ford says 5w-30, but I was out of grade to a 20wt within 5k. With my tune, Florida heat, running E30, turbo, etc. I decided to go with a heavier oil. This Castrol has stayed in grade and resisted dropping out of grade for longer OCI than the Penz Platinum I used earlier. No consumption issues over the 5k I was using the recommended grade. After 7700 miles I may have burned less that 1/2 quart.
