I can't speak for the 4.0, but the VQ30 will develop a miss in pretty short order when using Bosch for example. Nissan built the engine around a specific sparkplug and when cross referencing to another plug, things like heat range and reach can get lost in the translation. Don't be cheap, use the right plugs and be happy for another 100K. FWIW the VQ30 doesn't care if you use copper, iridium, or platinum, as long as its an NGK. If the spark plugs are easy to reach I would suggest coppers with more frequent changes. Copper is a better conducter, fore frequent changes will lessen the chances of a seized plug, and you will take a smaller hit to the wallet with each change.
