Originally Posted By: WobblyElvis
Then they specify the grade of oil for your engine.
Actually, as far as I know, they actually determine a fuel grade to use before they even start designing the engine, and then all the specifications and tolerances are put in place with that grade in mind. So I guess that would make it MORE important. But it is the hot number it is based on. So for instance, some oil brands actually recommend a 5W-30 in a 10W-30 car. I think Mobil1 was one culprit.
If it was a quick oil question, you would've had it all in one sentence.
Alright, you caught me.
Actually, what I meant was that I didn't need a huge answer, just a quick one because I was planning on doing this right after work which would have been about an hour later. Of course, we got yet another tornado today, so it may have to be a weekend project.
So 10W-30 is what I'll go with, then. Now the debate is between regular and high mileage.
The car runs dex-cool, and it seemed like it was prone to getting sludged up. Last time I did a flush, I did several flushes, because it came out like mud.
Now, it seems like it gets rather cloudy. Not as bad as it was, but it does make me wonder if it is getting contaminated somewhere. Either it is related to the intake manifold gasket problem, or the problem is elsewhere where oil would get in. I would think I would have MANY more problems if I was getting oil in my coolant.
But either way, I do wonder if I could benefit from those other additives. Or if I would swell the seals, cause them to retract, and thus create MORE leaks.
This was a lot simpler when I didn't no squat about cars.
