Originally Posted By: dlundblad
Originally Posted By: Trav
I rarely use extractors, when I do its when the bolt broke going in for some reason (usually a defective bolt) or just to remove the last remaining threads left in the hole.
I use cobalt or solid carbide left hand drills to drill it out, many times the bolt will come right out with the drill bit.
Don't use the spirals, you break one off and its a real PITA.
Use a fluted type extractor like these. Proto are decent and cheap enough for high quality.
https://www.zoro.com/proto-screw-extract...mp;gclsrc=aw.ds
With those extractors, do you use the left drill bit first then (assuming the bit didnt take it out,) tap the extractor into the hole?
Exactly. Like I said earlier, I rarely use them because I have always worked in the salt belt be it here or in Germany and easy outs of any type are no match for rotten bolts.
If You live in a climate where rust is not an issue drilling the bolt out up to the threads may be considered a last resort but in the rust belt it is 100% the best option with very few exceptions.
I deal with broken bolts, studs and rusted away nut flats on a daily basis
Believe me the better quality the easy out or tap the harder it is to drill out if it breaks.
Get some of these, get small sizes up to about 5/16, that will get most of the easily broken smaller bolt sizes.
This little set is really okay, it is 8% M42 cobalt which is very good and many times better than HSS or Ti Coated. You can get small size singles also.
I recommend buying 6 packs of the smallest sizes like 1/8" and 1/4"
http://www.amazon.com/Tools-Cobalt-64-In...hand+drill+bits
Again 8% M42 cobalt.
http://www.amazon.com/Irwin-Tools-30505ZR-135-Degree-Handed-Mechanics/dp/B00BRGLNOS/ref=pd_sim_469_1?ie=UTF8&dpID=51AcSB9ZfcL&dpSrc=sims&preST=_AC_UL160_SR90%2C160_&refRID=0V3KP10TQX6K9NPZNHVM
These are a must if you live in the rust belt, these have been a God send. I was skeptical at first but not anymore, the Irwin have held up very well and performed better than I ever expected.
http://www.amazon.com/Irwin-Industrial-T...+Bolt+Extractor
