Originally Posted By: Carbon
I would pump the tire up to about 80 PSI and then check for slow bubbles.
You can check for economical bubble solutions. 20% or so dishwashing liquid and 80% water is pretty good and cheap.
80psi, REALLY? Hard to see the leak, after the tire explodes. Just take the wheel off the vehicle, set the pressure to 30, and spray everything, and let it sit for a few minutes, then flip it over to the other side, and repeat. If nothing shows up, lower the pressure down to 10psi or less, and check everything again. I use distilled water to mix with the soap, which seems to make better bubbles. Pinholes don't always make bubbles at higher pressures.
