I am 2K miles from warranty being up so going over the truck checking everything. Today I pulled the neg cable from the drivers battery and but a BatteryMinder on it until done then measured CCA, was 717 out of 750. With the cable still off I put the BatteryMinder on the other battery until done then measured it 727 out of 750.
My questions:
1) The pos term on the passenger side had quite a green corrosion at the bottom of the post and bottom of battery connector. Its an JCI by the cell cover caps. Maybe I have a leaker?
2) As I put the neg cable back on (drivers side battery) it sparked a little and I noticed the mirror lights coming on. I do not understand why that happened. Aren't the batteries in parallel and the passenger battery should have kept the pickup powered up?
My questions:
