Originally Posted By: Ihatetochangeoil
Don't use PLASTIC coolant elbows. There are aluminum ones available. $10 is cheap insurance.
http://zzperformance.com/3800/aluminum-coolant-elbows.html Put silicone grease on them and they slide right in.
I even never mentioned plastic elbows at all.. I would never use them. My car already had the aluminum ones (probably was replaced at some time before), but I bought 2 new aluminum ones anyway since they were so cheap. I replaced them already.
So no one knows what those 2 black o-rings are for, that come with the lower intake kit? I called Fel Pro and asked and they didn't know either. But they did confirm that they include extra parts, such as the two sets of side rails (old and new design).
Originally Posted By: sciphi
Did you replace the gasket on the IAC valve, or mess with the screen in the throttle body? The IAC valve will make a loud hiss when it starts up cold.
That engine won't rely on the MAF for about 30 seconds after it starts cold when it switches to closed loop. On a warm start the switch happens almost instantly.
No I didn't even take the IAC valve off while cleaning the throttle body. Could that have messed up the IAC valve?
I am familiar with the loud hiss the IAC makes when cold, but it has a hiss when warm too. Also it has this noise when you rev it, all the time, cold or warm:
https://www.youtube.com/watch?v=TZrWDgy40RU (I know it's a Camry in the video, but it's the same air sucking sound)
The MAF screen is damaged. I know it's super fragile, but I'm pretty sure I didn't do it, because it's damaged pretty bad, and I didn't feel any time when I pressed against the screen or felt it give at all. It's ripped in two spots, and the mesh screen is pushed in a little. I was reading that I should probably either replace it or run without it, and not leave it in there damaged, but I need to get a set of snap ring pliers. Plus, would it really cause that noise? I guess it's possible, since all the air goes through there. The noise wasn't there before I replaced the intake, but maybe I did break the screen without noticing, though I highly doubt it.
