Originally Posted By: WellOiled
Originally Posted By: ZeeOSix
Originally Posted By: DudeNiceRide
The ADBV is not the only place oil can siphon back into the engine. If the seal between the gasket-retainer cover plate and the threaded plate is missing or incomplete, oil can & will leak through the gap (esp. nice hot thin oil like when you shut your engine off after a drive). There needs to be some type of sealing agent or glue in between the threaded plate an gasket cover, and it needs to stay put. If there is no sealer, or if the plates can move independently of one another, oil will easily pass through the void.
Purolater (aka: Tear-orlator) does not weld the gasket plate to the threaded plate and have been known to have issues with drainback and with installation. They "stake" the cover plate through the holes of the threaded plate. They tried to save some pennies by skipping the weld part. All the other major filter makers weld the plates together (usually spot welds).
Then the installation issue with the non-welded design is when there is some "give" to the gasket plate because its not fully seated. So when you're installing the filter on the engine, you THINK you found the point where the gasket touches and then give it its 3/4-1 turn. But what's really happening is the gasket is not really compressing -- the cover-plate is seating. So you get like 1/2-turn instead of 3/4-1. DUMB!
Guess I don't see how the leakage path could exist as you've described in the red text above. The ADBV (if working correctly) should still seal the base plate's oil inlet holes on the threaded base plate and prevent any oil from back flowing through the filter. Maybe someone can come up with a sketch showing a cross section of the base plate and the leakage flow path.
Imagine the filter is built with a one-piece base plate - seems it doesn't matter if there is another 'gasket holding plate' over the top of the main base plate because the ADBV seals on the inside surface of the main base plate. When an oil filter is installed tightly onto the engine, there is a sufficient seal between the base plate threads and threaded mounting spud to prevent any leakage if that is the path you assume the oil to be taking.
ZeeOSix - Sorry for the lack of quality on the sketch but this is what I have to work with.
Last night I took a look at some of the new filters that I had cut. The tapping plate is separate and distinct from what we see on the exterior of the base. In the case of a MC FL820S, there is a ring of spot welds under the gasket. If the tapping plate and the auxiliary base plate are not in intimate contact, a leakage path exists. The ADBV could be perfect and we still could have a leak in this area. The find hand drawn line would be the oil path. Drawing not to scale.
WO, I see what you're talking about. And, in theory, I
CAN see this happening.
