Originally Posted By: Pop_Rivit
Originally Posted By: Avery4
I checked the relay and fan switch and both are good. Is it harmful to ignore the problem of both fans running whenever the key is on? Will this cause a problem?
Since you rebuilt the engine on your Stratus, you should be able to figure out how to correctly repair the fan. Just fix it right and be done with it.
Cooling fan circuits I have looked at are "fail safe" in that the fan relay must be current through the coil to turn the fans OFF. A wiring fault will leave the fans on. The fan switch OPENS when the radiator is hot enough to turn on the fans. There are variations, such as running one fan all the time when the AC switch is on and circuits set up to provide more than one fan speed. O the Camrys I have both fans run when the AC is engaged, thus if operated in a hot climate like Florida they run for many months a year.
