Well I attempted to replace the cooler line fittings (along with the hard and soft lines and aux. cooler) on my 1996 Jeep Grand Cherokee 4.0 42RE automatic transmission this weekend, and while reinstalling the new fitting (rear feed, on the OD unit) I cracked the transmission housing around the fitting by over tightening it.From what I gather it is a common mistake/problem, as there was no greater turning resistance since there no stop for the fitting. I was using a 6" adjustable wrench and turning it with 1 finger. I had the wrench vertically above the fitting right near the TV cable spring(?) and was not cranking down on it at all. Seriously turning it with one finger, 1/8 of a turn at a time. That's all I could do in that tight space. Well that was enough torque to split the aluminum transmission case along the casting mark.
I was basically devastated when I saw the crack forming, thinking I totaled this 20 year old jeep doing preventative maintenance, but after some googling I think found a solution - Sonnax part #22000-01.
Does any one have experience using this repair kit Sonnax part #22000-01K? The instructions say to tap the hole until the tap bottoms out. Will that be obvious? Then It says to visually look for contact witness marks inside the opening. I'm not sure I can see into it, its tucked up into the transmission tunnel, should I use a mirror?
Sorry for the wall of text, just looking for any input to make this repair as painless as possible. I already used some marine JB Weld around the fitting, and its holding and not leaking, but I'm obviously not driving the jeep until I get this "repair" fitting installed.
