Originally Posted By: Astro14
It wasn't cut from dimensional lumber. It was a cut off from a larger flitch or piece. Visit a real lumber supply company (not Home Depot, or Lowes) and see what real (not dimensional pine intended for construction) wood looks like. It ain't cheap, however.
You can just find a guy with a saw mill too. Gets very cheap if you bring your own logs, but even buying a beam from them isn't too bad either. Almost all wood is cheap, its just the labor that gets added to process and handle, and retail it.
If you order a custom size from a small mill, and don't need it yesterday, the larger beams get cheaper per bd ft. as there's less sawing/time involved.
