Originally Posted By: DWC28
From an 2005 ASTM round robin on ATF D2983 with: number of valid results 30; robust mean 10668.8; robust std deviation 499.1; repro ASTM 634.5; repro these test data 1382.5. 3 sigma on that data would be 9,000 to 12,000 cP.
Thank you, so then the true outlier is indeed the CAM2 (as we've both noted) with its MRV that is well outside the margin of error. Any thoughts on that? Is it due to what I mentioned earlier, base oil interchangeability as part of the spec?
