Originally Posted By: MotoTribologist
Originally Posted By: vintageant
Supporters and Bashers, this one's for you.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4074727#Post4074727
I don't know all the details, but after a quick look, couldn't the addition of the external filter easily be the cause of the decreased wear metals in the oil?
The engine is still in the initial running in phase, so anyone who jumps to conclusions based on such a UOA needs to do their homework. The external filter could also be making a big difference.
Thanks Ramblejam for the 2 PDS copies of Kreen and MMO, they are obviously very different. Anyone got a real VOA, as I'm curious to know if they have any Mo or Bn anti wear / friction mod additives.
Disappointed they are both only HC synthetics and not the real thing!
The block might have been assempled with some special run in lube, grease or sealants AND it is probably going to dump Fe and other wear metals that were from the initial assembly anyway. The net result is a very confusing UOA where all you can confirm is that the viscosity is OK and the wear metals are trending down.
A lot of new or rebuilt engines will be running in to some extent for 50K miles (Might be 100K for a good diesel).
