Originally Posted By: dnewton3
I'm not taunting or harassing you, but if you really want to
KNOW how it's doing, I have three little letters for you:
U....O.....A......
Why guess when you can know for sure? Why not actually test the oil after perhaps 5k or 10k miles, and then post up the UOA and add to the knowledge base here, rather than just contribute to the ever-present presumptive lump of guessing on this site?
I mean if you're considering wasting perfectly good oil by dumping it out way too soon, then you should be willing to "waste" money on a UOA and actually learn something that you can share with all of us.
I've seen plenty of UOAs from Wolfs Head oils and they do as well as all other API certified lubes when used for the intended application and reasonable OCIs. But then again I tend to look at results and then make decisions, rather than guess based upon prejudice and supposition.
My apologies for the snarky approach, but blunt is what I do.
And - I will confess that I, too, was an oil and filter snob for a long time.
At first, I was ignorant of the oil and lube choices, and didn't care much.
Then, I got sucked into marketing hype and mythology and rhetoric; I didn't know better.
Now, I use data analysis to show me the reality, and then make my decisions accordingly.
The truth shall set your wallet free and your mind at ease.
The next UOA would probably be poor anyway, due to the engine being opened up when the pan was dropped to change the gasket.
I've done plenty of UOA's on the Dodge and posted them here, so my OCI has been developed for RT6. I'm not going to throw that effort into the trash because the shop didn't ask me what oil to put in it.
