I seek BITOGer wisdom,
I have a nasty problem with my 2005 325i. It has about 100k miles. When you drive it at high speeds (100 km/h or faster) I get steering wheel vibration very similar to one you would get when your wheels are unbalanced. It's only in the steering wheel, not the cabin. It gets worse with speeds, and it's always there. It happened after I rotated my tires. Since then I've done the following things (chronological order).
I don't want to get into why I did the following work, and make this post too long and complicated. All work was performed by professional mechanics, so no DIYer mistakes. I've been to 4 different shops: tire shop, alignment shop (tire shop doesn't align BMWs), two different independent mechanics. I am using OEM BMW wheels, and OEM tire size.
-tire balancing (no change)
-tire balancing and rotation (no change)
-changed front control arm bushings (they were worn) (no change)
-changed front rotors and pads (no change)
-4 new Continental tires (no change)
-4 wheel alignment (no change)
-another tire balancing (no change)
-tire rotation and balancing, wheel hubs were checked (no change)
-changed both tie rods and alignment (no change)
-two new OEM BMW wheels in the front (slight improvement, vibration starts at 100 km/h instead of 80 km/h)
At this point I think there may be two possibilities: bad tires, or some other suspension problem?
I doubt it's the tires because it would mean all 4 of my old tires were bad, and all 4 of my new tires are bad. I also bought good tires.
The only sort of clue I got was the tire shop mechanic said my rear trailing arm bushings and other rear multilink bushings were worn. He said my front suspension is good but the rear has worn parts. Can worn rear trailing arm bushing cause high speed steering wheel vibration? An independent mechanic who also serviced my car doesn't agree with that diagnosis though. The car is RWD BTW.
Another possibility is that my old wheels were bad since there was some improvement with the new ones, and I just got a bad balance on the new ones.
Maybe I should have replaced my control arms entirely, and not just the bushings?
I'm thinking I should replace my rear trailing arm bushings, and replace the rear shocks to stop rear suspension travel, since it should be relatively inexpensive. At this point I do not want to guess and replace things, but I don't have any other leads.
