Originally Posted By: 440Magnum
Originally Posted By: Jetronic
I like 5 cilinders myself... sure the crank isn't flat, but you also never have more than 1 cilinder passing a dead center.
Never driven a V10 but based on my 5L experience I'd very much like to.
No 2nd order imbalance on an I5, but like a 3-cylinder there's a "rocking" moment that has to be cancelled with a balance shaft.
Most V10s are odd firing and built on a 90-degree V with non-splayed crankpins. There's enough cylinders and overlap that the odd firing doesn't produce any roughness like it does when you try it with a 90-degree v6, but it does make a funky 2-notes-at-a-time exhaust tone. Especially noticeable if you only hear one bank at a time, like on a Viper with side-exit exhaust.
The first gen 5 cylinder diesel I had came with an extra balance shaft, but the later versions didn't. I suppose they added extra weight to the crank, but never investigated.
