Was just about to order oil from amsoil for my truck an Expedition 2007, my mothers Lexus Gs430 and my 2003 Infiniti m45. This might be too expensive for me , I thought with the total coming to about 200 bucks! without filters.
Just asking for advice, Trying to find a cheaper oil that offers more protection or the same.
My infiniti m45 calls for 5w-30, and is driven in summer only, Very hard. I usually change it 5-6k intervals with a purolator pureone filter.
I live in the midwest so it gets hot and muggy quick. I have a 370z or 350z mishimoto radiator and electric fan mod. I also removed the rear thermostat and gutted my pre cats. The front thermostat is now a 170 or 180. I cant remember if I put a higher degree theromstat back in place or not. So I'm guessing my oil temps are perfect due to my coolant temps being much lower.
Daily driving is highway usually longer trips. I try to avoid shorter trips around city and walk or bike when I can. does burn a slight bit of oil. But since I switched from a mix of amsoil and some 5w-40 rotella the first oil change, then full amsoil the second. I has laying around and I've been driving very spirited on it constantly. the oil consumption had went down quite a bit. I've only put two oil changes on this motor.
My Infiniti motor I replaced after I threw a rod bearing in the old one. There was so much metal in the oil, this was coincidentally the day I was going to switch to amsoil. There is 100k on this motor.
My mothers gs430 calls for 5w-30 too. She is getting old and doesn't work or put much miles on her car, perhaps I should do an oil analysis on her vehicle.
