Photographer by trade. I have had to recover to failing 2 gig hard drive. Someone created a batch file with using Robocopy but it doesn't work. Researching, and this is part of it, states the command line needs a folder to folder copy. His code was basically "E: F: copyall and then a couple of switches. It didn't work.
I could just create a single folder named "Alpha" and then move everything into that. Then I could us ROBOCOPY to copy that entire folder into another folder on teh destintion drive, then open that and move to the root directory.
What is wrong, or what command prompt will copy data e: f: preserving all files and structures.
The bigger problem is trying to combine files on a failing hard drive. (It became a single directory at a time)
