Having read a discussion on another board, what is the feasibility/ safety/ wisdom of trying to plumb in a fuel-run water heater into the cooling loop of a diesel vehicle with the idea of having something that will pre-warm the vehicle out of range of an electric plug in so that it will start well even in very cold weather?
An example would be here: http://www.webasto.com/us/markets-produc.../water-heaters/
There are electric sources for everything, but limits on how much power you can run through one plug. (fuel could get hotter faster) I've seen systems where the coolant is plumbed to preheat fuel lines, fuel tank and everything else that can gel up in -40 temps - that works great when the engine is already running, prewarming and precirculating the coolant gets all that started.
Plus all the endless discussions of how an engine has greatly reduced wear when starting at real running temperatures (above even summer 'cold' temperatures) makes me wonder if running such a heater year round would make sense if you could flip it on in advance of normal vehicle use to get to and maintain normal engine temp. (assuming you didn't mind the fuel usage) Since 120vac free plugins just aren't available in most places that means fuel powered heat is the way to go.
Now talk me into or out of it.
