2002 Ford Ranger 133,000 miles
V6, 3 Liter
5 years ago, I had a coolant leak behind the Timing Chain Cover.
Had it repaired at the Dealer (yea, I know).
It was to much work for me to handle.
I believe that right after that repair it was still (slowly) leaking, but in a different area.
I added some 'dye' and an Indy Mech could not locate it, nor myself.
Fast forward 5 years (today) and I have coolant leaking on the ground.
Reservoir was down 3/4" over Winter. Not a big leak.
I can now clearly see it's leaking around the Timing Chain Cover (again).
I figure the Dealership did poor quality work.
I want to get it fixed at a Indy Mech (I believe is reputable).
Probably a $950. repair cost - OUCH
My concerns: Which I will discuss with Indy Mech.
1) Will they just rely on another Paper Gasket or would it be better to use a Silicone type gasket maker in a tube (Permatex brand) ? ? ?
I myself was impressed using Permatex Ultra Black on the Diff Cover.
2) If the aluminum cover is corroded, what will they do.
A new OEM Cover is $200. on E-Bay
A Dorman Cover is $140. on E-Bay
If there is any corrosion, a Paper Gasket would be useless, would they then just use a Permatex product ? ? ?
3) If any coolant is added, make sure it meets Ford spec.
I am very disappointed in the work the Dealer did and I want to get this fixed correctly.
I do not want to be spending $1,000 every 5 years.
Later today I will check some Ford Ranger Forums.
Any advise would be appreciated.
Thank you.
V6, 3 Liter
Thank you.
