This is a friend truck that I change the oil on. He wanted to go 10k on oil changes. Thought I would pull a sample and see how it went. This is running an EaO11 filter.
Code:
You just pick up this F-150? If you did, we'd say you know how to pick 'em. Averages for the 24-valve 5.4L Ford
are based on oil run about 5,800 miles, but a longer run didn't bring about any poor wear in this engine. It's normal to
see iron read higher after longer runs, and it's actually better than average when you take miles on the oil into account.
This fill of Amsoil showed additive left at the end of the run with a TBN of 2.3. A trace of fuel is harmless and won't do
any harm. Running the next fill up to 12,000 miles would be fine based on these results. Nice pick-up!
OIL ASM 0w-20
MILES IN USE 10,100
MILES 100,939
SAMPLE TAKEN 3/29/16
ALUMINUM 6
CHROMIUM 1
IRON 25
COPPER 2
LEAD 0
TIN 0
MOLYBDENUM 147
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 54
SILICON 12
SODIUM 9
CALCIUM 3551
MAGNESIUM 31
PHOSPHORUS 610
ZINC 692
BARIUM 0
INSOLUBLES 0.2
WATER 0.0
FLASHPOINT ºF 385
SUS VIS 210ºF 55.8
cSt @ 212ºF 9.02
Fuel% TR
Antifreeze% 0
TBN 2.3
Code:
OIL ASM 0w-20
MILES IN USE 10,100
MILES 100,939
ALUMINUM 6
CHROMIUM 1
IRON 25
COPPER 2
LEAD 0
TIN 0
MOLYBDENUM 147
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 54
SILICON 12
SODIUM 9
CALCIUM 3551
MAGNESIUM 31
PHOSPHORUS 610
ZINC 692
BARIUM 0
INSOLUBLES 0.2
WATER 0.0
FLASHPOINT ºF 385
SUS VIS 210ºF 55.8
cSt @ 212ºF 9.02
Fuel% TR
Antifreeze% 0
TBN 2.3
