it sound like the wire are not properly hooked up or placed on the engine . like a lot of wire are creating false positive or false nagative( induction of temperature signal or induction of voltage. verify and make sure everything holding the wire are made of temperature resistant plastic clamp and put temperature resistant tape on those wire that you cant put away from engine or whats not . make sure the big wire for alternator ,battery , starter are once inch away from everything . yep those literally have to be isolated . all the ground you need should be took from the fram ( i mean the small wire. dont go grab ground on the battery . only thing batter is for is to start the engine and supply electricity via frame.lastly check the pcv valve and tube related to it, make sure nothing is pierced and is working proper.
