Originally Posted By: dkryan
Originally Posted By: HTSS_TR
I had Mityvac 7201 sine 2002-2003. It works well for over 10 years doing oil change in my 2000 MB E430. I then used it to do oil change, ATF, brake bleeding ... for other cars.
Yeah, don't over pressure any fluid extractor. I pumped 8-10 times to extract 8 quarts from E430, it took about 8-10 minutes and this is the time I used to change to cartridge oil filter.
Mityvac 7201 has markings of 2-liters on the container.
8 to 10 pumps and that's it? No need to pump a couple of more times when the fluid removal begins to slow down? Or is it my typical impatience?
With warm oil(about 110-120F or a little hotter) I just pumped 8-10 times, with cool oil I pumped few more. I spent that time to swap the cartridge filter. When I'd done the filter usually all oil was siphon into the Mityvac container.
Once every few years tighten the 6 screws on top of the container, to keep air tight.
Originally Posted By: Donald
I also vote for the MV 7201. It can bleed brakes also.
MV7201 is a much better tool to bled the brakes than Motive Power Bleeder and probably any other tool.
Easy, fast and no mess. After connect the hose to bleeder screw and pump 4-5 times all you need to do is watch the fluid level in the master cylinder.
Personally, I think MV7201 is the best tool for car I bought in the last 20-30 years.
