Originally Posted By: detroitengineer
The camry other headlight went out. I am engineer20, back. For some reason, e20 was banned, I'm not even sure why, as I backed it up with photos. I got the oil filter off, and changed the bulb with sylvania extravisions, but after instaslling the bulb, a few days later the other side went out! could this be an alternator problem?
Also, can I use just wobble extensions without a need for staright extentions as I bought 9.99 harbor freight extensions with a coupon, normally 14.99.
Also, what about goop silver automotive grade, to fix the bottom of the trans case? It's still leaking thru the black rtv. I heard the goop was even better than jb weld and I got it half off at this advance auto in the area that was closing and it will close its doors permamently this saturday, so while everyting's half off, I might as well get the headlihgt, and also headlights for the 09 taurus, and I bought the motorcraft spark plugs which were platnium and the spark plugs in the taurus were platinums, as I checked a front spark plug, and got it for 2.45, half off from 4.99, from advance auto, which is cheaper than the dealer which sells the same plug for 6+ dollars.
And here we thought you were gone seeking the professional help you so badly need. I truly feel sorry for your family, coworkers (if you have any), and anyone unfortunate enough to cross paths with you in their daily life.
