I've searched around here trying to get caught up with ethanol fuel additives.
Hopefully I can get a simple, Easy answer.
I have a fresher built high performance AC 2T scooter engine.
I have been adding 1oz of Stable Ethanol Fuel Treatment to each 5Gal of 93 octane, E10 gasoline that I mix with a 36:1 ratio of 2T oil.
I've been adding it in an attempt to maintain a quality fuel blend and prevent any of the negative reports of e10 in small, carburetor 2T engines.
I don't know if it's absolutely necessary, or if it is beneficial at all. I was actually somewhat concerned if it could be detrimental in any way.
I just uses the last of the Stabil, and was looking at products on the shelf at the store. There seems to be a few different brands that are readily available.
Is there any reason why I shouldn't be using one of these additives?
Are there any positive thoughts on the Lucas Safeguard Ethanol treatment? I've noticed over the years that there isn't much positive to say on Lucas Fuel Injector/UCL which was been around for a long time.
STP Ethanol is another option. Never been an STP guy. Should I become one?
Stabil Ethanol. Should I simply keep using this?
Without any info, I was leaning toward using the Lucas Safeguard. It seems to be a better value than the Stabil, and the printed info on the bottle sounds good. I don't know if there is any real cleaning to be done on a 2T engine, and I don't think any of these would really do much.
I'd prefer to use something that I can buy locally off the shelf that doesn't cost a fortune.
Thanks!
Thanks!
